Televison & Video Logo
Posted on May 02, 2009
No instructions for a goodmans remote
Our tv was tuned into the sky remote we now have virgin and need to re tune the origional remote it is a goodmans tv
  • Anonymous Mar 28, 2014
    i need to retune a universal remote to my goodmands tv
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on May 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2517
Points
8
There are a few numbers for a goodmans tv (the codes are for gemini 6 in one)they all enter 3 digits
002 004 009 027 028 051 068 093 111 115 127 153 169 171
hope that helps
1helpful
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
1helpful
I've got a goodmans tvc202ts with no remote can i still tune it in and how? or can i tune it in if i set up my sky remote?
Hi, if you connect your sky box to the TV by SCART the TV will automatically switch to aux so you can watch sky that way. The same goes for DVD players, digiboxes etc, but not anything that connects with component video like my Playstation :(
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
1helpful
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
2answers
Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
RECENTY PURCHASED SECOND HAND TV WITHOUT REMOTE OR HANDBOOK CANNOT SEEM TO SET UP MY SKY BOX TO IT ANY SUGGESTIONS?
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Tuning in SKY remote control with Orion TV
buy a better telly
looooooooooooooooser
HUMAX TV
Hi.
Try this,
It involves finding your make & model number from Sky.
Press INTERACTIVE BUTTON., then SKY CUSTOMER SERVICES,
then TECHNICAL ASSISTANCE, FOR ALL SKY REMOTES.
Now follow the on screen instructions.
http://dysonmanuals.inc.io/
Chris.
Tuning the sky remote.
Phone LG service in Slough, they have the info
Top Gemini Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Gemini Televison and Video Expert? Answer questions, earn points and help others
