Fuji Finepix S1500 10.0 Megapixel 12x Optical Zoom, 2.7 Inch LCD Screen Digital Camera Logo
j
jeninds Posted on Nov 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Needs a factory reset
How do you do a factory or hard reset
Harrie
Level 3:
Top Expert:
  • Fuji Master 6,746 Answers
  • Posted on Nov 10, 2013
 Harrie
Fuji Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285459
Points
83153
The only reset I can find is on page 89 of the manual.
link to FujiFilm Finepix S1500 manual
Testimonial: "Thanks, not sure where that is, but i think my mom might have one or i'll look for a manual online, thank you"
2answers
Menu 0000 is not working and I need to factory reset tv
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1helpful
3answers
How do I reset my tv without remote control?
Without the remote control, you can not do a factory reset; Can only of the hard reset. There are two methods to reset TVs. The first is simple to do; Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it to reset system [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the website linked here. Pull up older posts. Http://electronicshelponline.blogspot.com/
Service entry mode, adjust and exit procedure to many popular brand are given Beheerder TVs. Never forget to exit the service mode, after all adjustments Have Been done.
I need to manually reset to factory settings
It is not possible. You should have a remote control to do a factory reset. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
S5600
Samsung S5600 Preston Hard Reset:
  • Press and hold Volume DOWN + Camera + POWER Until Samsung menu Appear
  • Now you see android recovery menu
  • Now select Wipe data/factory reset and press power key to confirm
  • Now select Yes -- Delete all user data and press power key to confirm
  • Now reboot device
  • hard reset done
Hard Reset By Code:
  • Enter Dial number *2767*3855#
  • Now you see Factory Format
  • wait until factory format complete
  • after factory format handset will be reboot
  • hard reset done
Apr 24, 2014 • Cell Phones
2helpful
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
21helpful
2answers
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
