My sled will not start using the electric starter. I can manually start it using the old pull roll. When I use the key to start it I hear a thump sound each time I turn the key. The sound is coming from a small black electrical part next to the battery. A switch or solenoid?????? The starter motor doesn't even have a chance to start the motor. Just hear the "thump."
Fix your problem right away,by clicking the link Best Manuals
SOURCE: I have a 1999 Polaris Rmk 700. 136 inch track.
check and see if u have ice on the back suspension
that would lock the track up or make the motor work harder that being it will bogg down
SOURCE: 1997 Polaris rmk 700 has no spark. Kill switch is
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
SOURCE: I have a 2005 Polaris Trail Boss That wont turn
attempt to start the engine in neutral using a battery charcer/starter on the starter connectors only if the engine turns over replace the battery cables if not; you have a seized engine
Could be time to replace battery, this is most likely the culprit. These fourwheelers are very picky when it comes to low power. Your starter is also most likely just fine, the clicking you hear is the solenoid on the starter, so your battery has some juice, but not enough amps to turn over the starter. Also If the fourwheeler has sat for a long time then you may just need to charge the battery. The 2007 is most likely fuel inject which uses even more fuel when running and it also has its own computer kind of like a PCM in a car or truck. These all need a good supply of power and the stator which is like an alternator usually needs the help of a fully charged battery to keep everything running properly. Also note, once you get a new battery or charge it in some cases the ATV should run smoother.
