If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
The Nikon F3 uses standard 35mm film, also known as 135. The type of film you use is up to you. You can use black&white film, color transparency (color slides), or color negative (color prints). Prints are generally cheaper than slides but slide films generally produce better results, and prints can be made from slides. You can also make black&white pictures from color films, though obviously you can't go the other way. These films are available in a variety of speeds. Faster films let you shoot in lower light and/or with a faster shutter speed for stopping action, but slower films have finer grain. Different films also have different color properties. No film (or digital sensor, for that matter) reproduces every color exactly. You may need to experiment in order to see which film gives you the colors you like for the types of pictures you like to take.
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Yes, you can get 35mm in color negative or black and white. Although the black and white film may be in 2 varieties: traditional process black and white(not all labs can process this) and C-41 process black and white (and one hour lab can process this). If you are looking for color film choose the C-41 color negative film like Kodak gold 400 or Fujicolor 400.
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
