Looking for a manual to camera my husband got me. Pentax program plus, not digital. older camera Did a test roll of film. I only got 4 pictures from full roll of film that were usable, all others were blank prints. Flash was used. I would like to get a manual so that I can learn more about the camera and be able to use it.
If you go to http://www.pentaximaging.com/support/manuals-and-literature/ and put in Camera's then Film Point and Shoot then under models put Pentax IQZoom 160 it will let you download the manual to your computer. Hope this helps.
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
This question has been answered repeatedly.
Pentax error codes are mostly for camera repair technician
diagnosis and most of the time mean the camera is broken and
needs professional servicing.
Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can
appear when the film is inserted incorrectly, when the batteries
are changed in the middle of a roll of film, if you are using
defective film, etc. If "E" appears in your camera's
information display, try to rewind your film manually (see your
user's guide for instructions on how to activate your mid-roll
rewind function), and try a different roll. If this problem keeps
occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your
shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom
lens.
H0-H9: These H codes can also identify a problem with your
camera's shutter.
U1-U9: These U codes may also indicate a problem with your
camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Depending on which series (screwmount, K, M, etc) you have, you'll get different levels of functionality, but yes -- all Pentax lenses for 35mm and DSLR (except for the medium-format digitals) will work with your K200D. Read the manual.
It's hard to tell without looking at the film itself, and it would help to know what type of film you are using (black and white? color?). My guess would be a light leak. If the film is exposed to any light, that results in a black picture, possibly blotches of color. Either you opened the camera before you rolled the film back into the canister (unlikely), or your camera is responsible for the light leak, in which case, you will have to bring it to a repair shop.
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
