Don't know if this is your problem but sometimes ours will appear to drain, but there is still a lot of suds that remains and trips the nd (no drain) indicator/lockout. We had to pour water in from a bucket to beat down the suds, then repeat several times to get all the suds out. First time I took off the back of the washer, disconnected the pump, then let the suds out. To much work.
SOURCE: My washer stops before the rinse cycle because it
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
SOURCE: it won't drain, code nd.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: Maytag 5500Bww washer wont drain
I had a similar problem along with many others. After replacing the door switch, seals, and bearings I learned a liile secret that will save you hours of frustration and lots of money (this virtually eliminated all problems). Get rid of it. Load it up, get it out of where you live, put as much distance between you and it as fast as possible.Take it to a scrap yard, they'll give you enough $ to buy some beer etc.Then get on your knees and ask GOD to forgve you for buying a WASHING MACHINE THAT HAS CIRCUIT BOARDS IN IT.
heatman101
