I bought a a Jazz digital / camcorder camara but I don't know how
To recharge the battery. The power supply cable or transformer was not included or part of the package. Actually I don't know if one is part of the package. Thanks for your help
My cam did not come with a power cord either< I have tried to plug it into the computer to recharge it however it does not work :( does anyone know where I can get a power cord?My cam did not come with a power cord either< I have tried to plug it into the computer to recharge it however it does not work :( does anyone know where I can get a power cord?
More than likely the camera has an internal problem in the power supply section. There is an electronic switching circuit that switches between the battery input and the DC input coming from the AC adapter. Your camera requires professional servicing. One such place is AVRepair.com Home Services Consumer Camcorder Sony
you should be able to charge the battery using a usb cable from your computer. see photo for type of usb cable you need. this cable should have come with the camera.
Many chargers will "cook" the battery if left in too long. Should be a thermal switch to stop charging when full and hot.
Also most batteries have a useful life of a couple years. If too dead wont charge. Come up with another way to power the camers
according to the manual guide, you cannot use another recharging, only
the recharge that came with the camera, because you can get a problem on
the screen.
you have to use this ADAPTER>
Sunny* SWITCHING ADAPTER
MODEL: SYS1196-0605-W2
PART NO: SYS1196-0505-W2-C
INPUT: 100-240V-0.3A MAX 50-60Hz
OUTPUT: +5V_-_1.0A
OUTPUT POWER: 5W MAX.
The battery in the camera is likely not a rechargable one. Check the print on the battery. Mine was not so I assume your is not as well. The maker of the camera was pretty cheap not supplying a rechargable battery, for the price they ask for the camera.
One possibility is that perhaps the USB port in the back of your computer may not be providing enough power for the camcorder to recharge or operate properly. Do you have another USB port to try?
If you are using desktop computer workstation, you may want to add another USB card to your computer.
The Charger has a standard two pronged plug to go into the wall. The other end goes into the camera at the back bottom. You will see the female received for the male plug.
the two AA batterys go dead in about 10 minunets of takeing pcktures
is there a why to charge battereies
