I have a Toshiba Satellite M115-S3154 Laptop that I have created and edited video on that I would like to send to my Sony Handycam only problem is I have only USB ports on the laptop for that the IEEE 1394 cable that is required for the DV hook up on the Camcorder. What can I do...can you help
SOURCE: Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
SOURCE: rca vhs-c camcorder cc603
HI DEAR
You can use a mPeg card, like a pinacle dc 10, broadway card,
or a TV Tunner card
oke
cropp
SOURCE: MINI USB CABLE
hi!!!
you can buy also for that in a surplus computer shop
or in computer shopping
center
not in online it takes you time to recieve it!!!
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
