SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: how to replace the selector control knob on a
Push-in center knob and and turn Counter Clockwise to loose it from the treaded shaft. Next, without Pushing in, continue turning CC till it comes off.
If necessary, remove the outer indicator knob by sqeezing the two release clips in the center. This knob is keyed to only go back on one way so you don't need to remember its location before removal.
Reverse the process to install new knobs.
Oh, if you need to replace the cam or timer which are behind these knobs, the front panel will have to be removed by first removing the top cover of the washer. Now you can access the six screws inside the washer and one in front behind the detergent dispenser.
SOURCE: my front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
