How do i get my kenwood car stereo off of protect mode
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
SOURCE: Protect mode Kenwood KDC MP438U in dash reciever
Anytime there is a short circuit or your battery down low enough you will recieve this signal. If you press the little "reset button" using a small pin or screwdriver your unit should reboot without the "PROTECT" signal. If seeing this "PROTECT" sign is a result of jumping your car, this will fix it. If the signal persists, then there is still a short circuit and you need to check your connection with the battery. Most likely it is touching the chasis or some othere metal.
SOURCE: Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
SOURCE: My Kenwood car stereo keep falshing the word "Protect" how to fix
in front of your #1 preset button there is a reset button push it with a pin. if you made a pass # put it in if not page 12 show you how to make one if you want. reseting it should make it work if it dont you have a short somewhere start from scratch buy taking it out. I suggest you dont make a password till the short is gone. Mine did the same thing but because i was pulling to much power on starting my car with my amps.
