QUICK!!!!
Get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
Quick Charger 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
You can only do in-camera charging with C613 if you have a camera dock series 3 or a printer dock series 3, G600 or G610. Otherwise, you would have to take them out and charge the batteries with a separate charger.
If you have the battery pack Kaa2hr - charge it with Kodak k4500
if double Ni-mh batteries - charge them with K620 or any ni-mh chargers.
make sure the rechargeable batteries you have are ni-mh. it wont work with other rechageable types. ;)
SOURCE: Won't hold a charge
what rechargeable batteries are you using and what's your method of charging?
If your using a dock for charging - make sure you have the battery pack kodak kaa2hr otherwise the dock won't charge it
if you're using a separate charger - it's ok to use other AA ni-mh
please check the age of your batteries as well.. batts, even rechargeable eventually wear out - they can last up to 300 charging cycles and a year or a little more than that is enough for you consider buying a new set
if you say that you barely use the cam, batteries still deteriorate through time
SOURCE: batteries don't hold charge any more.
The batteries will only last for about 200 recharges. Depending on how you use the camera and batteries. Try with new batteries.
In order to buy new batteries contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Alternatively buy them directly online.
http://store.kodak.com/store/ekconsus/en_US/list/Accessories/Batteries__Chargers/categoryID.28887900
Charge a kodak with what your question was cut off please ask another question- thanks
