My Toshiba Laptop, Satellite A135-S4407, has been showing a blank display for several months. I use it hooked up to an external monitor, everything works normally with that. You can see all the normal display activity on the blank laptop display if you put a flashlight up against the glass. When the problem first happened the laptop display would work normally for a minute or two, then go blank. Now, when I boot up the computer there is a brief flash of full display light on the laptop screen, often orange in color, then it goes blank. This laptop is 2 years old, the problem has been in effect for less than 6 months. Warranty expired after 1 year.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Yes, the external monitor works fine and the laptop works fine. All the windows functions are present on the laptop display when you shine a flashlight onto it. It appears to be the CCFL lamp, maybe the inverter. Each time I "awaken" the laptop after it has dozed off in low energy mode the laptop display flashes orange for 1 or 2 seconds and shows the complete display normally while it does this. Then it goes dark. If the inverter was bad would it do that? Seems like it might be the lamp.
Thank you for the help. I have read over how to order and replace the back light. This will take time and will require a series of careful steps to complete. They do fix if for you, $75 plus shipping and insurance, so that could be an option.
