yeah i was thinkin something to do with the lid .sometimes all i have to do is move the lid or open and close it and it starts. any idea how hard it is to replace .yeah i was thinkin something to do with the lid .sometimes all i have to do is move the lid or open and close it and it starts. any idea how hard it is to replace .
You can't post conmments that contain an email address.
you say after you hit the top it start back? there is a sensor switch on top for the lid. it may be the senor switch for the lidyou say after you hit the top it start back? there is a sensor switch on top for the lid. it may be the senor switch for the lid
The issue you are experiencing with your washing machine may be related to a faulty lid switch or spin cycle sensor. The lid switch is responsible for ensuring that the washer lid is closed before the machine starts filling or spinning. The spin cycle sensor controls the speed of the spin cycle and may cause the machine to stop if it is not functioning correctly.
I recommend checking the lid switch and spin cycle sensor for proper function and ensuring that they are not dirty or damaged. If the problem persists, you may need to replace these components.
I agree with Tom C. I had a washer and the magnet rusted and stop being affective which made the washer think lid never opened or closed. For it to work properly the lid must open and close. If the lid interlock, as Tom said is faulty. Chances are it will not work. When I did happen to mine I bypassed the magnet and put a toggle switch on it to simulate the little opening and closing. It was a weak fix but better than spending $600+ on a new washer.
Check the door safety switch. Sometimes you can rock the lid left and right and close it back it might clear what's blocking the switch. Make sure you have the washer on.
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
The lid switch will need a slight adjustment to properly activate, or you could bend the raised bump on the back of the lid out a bit so it activates the switch better.
try opening the lid a couple of inches and close it down a few times,do you hear a clicking sound?if not the lid switch is bad.on the right side of the lid you should see a piece of plastic connected to the lid that fits into a hole in the top of the washer,this hits the lid switch,stick a pen or something in the hole and see if the washer works,send the model number and i'll tell you what switch you have on your washer,the model number is on the back wall of the opening where you put the clothes into the washer or to the left of the lid switch.if your lid opens strait up and backwards the number is directly under the lid when it's in the open position
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
any idea how much and where thats located on the machine
