Tablets & eReaders Logo
WAYNE GAFFORD Posted on Nov 11, 2013
I HAVE A TBS "T-PAD" THAT I NEED "DETAILED" INSTRUCTIONS ON HOW TO FACTORY RESET OR HARD RESET. I HAVE NO MONEY TO TAKE IT TO A REPAIR SHOP , HELP ME!!!
NEED "DETAILED" INSTRUCTIONS FOR A FACTORY RESET OR "HARD" RESET OF A TBS "T-PAD" model#M713. HAVE NO MONEY FOR A REPAIR SHOP, HELP ME!!!
Ashley Tennant
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 42 Answers
  • Posted on Nov 11, 2013
Ashley Tennant
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
42
Questions
Helped
7310
Points
54
You should be able to go into you settings and find the factory reset there and before reseting it check to see if there is a back up and restore box if there is click it so when you turn the tablet back on you should be able to restore all of your apps and music content back.
1helpful
PLEASE I USE IRULU BUT I WAS TRYING TO REINSTALL IT BE IT WENT OFF NOW HAVE CHARGE THE PAD BUT HARD TO REINSTALL PLEASE HELP.
You need to fully charge the tablet and THEN do a factory reset. The hardest part is waiting.
Follow the steps provided below to perform a Hard Reset on your iRULU Android Tablet:
  1. Turn your iRULU tablet off.
  2. Press and hold the correct key combinationto boot your Android tablet into Recovery Mode.combinations, which include:
  • Home button + Volume Down button + Power button
  • Power button + Volume Down button
  • Power button + Home button + Volume Up button
  • Power button + Volume Up button
  • Power button + Volume Up button + Volume Down button
  1. Release the power buttons once your screen turns on, and the device vibrates. Keep holding the other buttons for 10 seconds.
  2. Your Tablet should now boot into Recovery Mode.
  3. Scroll down to the 'Factory Reset' option using the volume down key.
  4. Select the 'Factory reset' option by pressing the power button.
  5. Now your Tablet will start the hard resetting process.
Once the process begins DO NOT press any buttons and don't try to turn the device off.
Your tablet should now be reset.
How do i take the factory security off my tablet i,m 65 years old
You need to do a "hard reset" this will erase any information you have stored and reset the tablet to the out of the box factory settings. I need the make and model information to provide any details as to how to do the hard reset. Or you can google it. By the way I'm 68.Please explain why age be a factor in this problem?? You are as old as you let your mind be.
Android box is steying on logo
Hold the power button down for about 20 seconds to hard reset the device. If it still only comes back to the logo you will probably need to factory reset the tablet. Consult your device documentation for instructions on a factory reset or google Factory Reset <Device Name>
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
