These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Hi there are a few things that could be bad on this TV. the first thing I would check is the T-con board if that's not the problem then the signal board and last the screen itself. If you are planing on doing it yourself you can get parts from www.interliquidparts.com
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
