Have you checked the adapter and if no power is coming at all??
Let me know when u give command from your system what error message comes up..
If any printer spooler error occurs, or in tray showing printing..
then let me know, I will assist you further.
SCOTT
Nstall the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side.
If this occurs, close the top cover, and open it again.
2. Open the paper output tray.
Note: When installing the print head, proceed to step 3.
When installing the ink tanks, proceed to step 6.
3. Raise the print head lock lever.
4. Pull out the print head from its package, then remove the orange protective cap from it.
Note: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>.
Doing so may cause printing problems.
5. Place the print head in the holder and lower the print head lock lever carefulAm installing ink tanks for - ip3300_install_ink_ph.gif.
6. Unpack the ink tank and pull the orange tape off completeAm installing ink tanks for - takeofftape.giftion of the arrow and remove the film.
Note: Tear the orangeAm installing ink tanks for - removecap.jpgly along the dotted line. If the orange tape remains, printing problems may occur.
7. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
Note: - Do not touch the ink tank contact <1>.Am installing ink tanks for - ip3300_install_ink_tank.gifg problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
8. Insert ink tanks into the print head.
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
10. Close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
HI,
Have you installed the print head? It's a separate item in a foil colored sealed package. It must be installed and locked in before inserting the ink tanks. If you have done this and still get no lights on the ink tanks, there is something wrong with the unit itself.
please rate my suggestion...
Are you talking about the LED's as Lamp light.
Please let me know the make and model of the printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00634936&lc=en&cc=us&product=1142684&dlc=en
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00059209
Thanks
Kevin.
Kevin,
I hope to hear back from you very soon. My printer is a Canon PIXMA MX700.
Thank you
Dory
After installing the print head and cartridges on my Canon PIXMA MX700 printer, the 'ink lamp light' is supposed to light red, but no lights appear.
Yes I have installed the print head. That is, if it is the black unit with slots in which the ink tanks fit. I've tried to remove the ink tanks. Have tried, unsuccessfully, to remove the print head. I reload the ink tanks and still the light does not come on.
Thanks for your prompt reply.
I have followed all the instructions, but there was never a light that came on. I am unable to remove the print head. It seems firmly settled and I don't want to force it.
