Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague http://www.badcaps.net
More likeley to have bad caps in the power supply, that is the first place to look, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
VA 730 may have the same chassis as VA720. If the cpas are bad, you should replace them with PANASONIC FM or FC series caps from DIGIKEY. Your college should have good electronics test equipment to repair these monitors.
You will need to disconnect the VGA cord that is connecting the monitor
to the hard drive. Once you have that disconnected, try attaching
another cord to determine if the cord is the issue. If you dont have
another cord to test, then you will have to purchase another one from
your local computer parts store and attach to determine if that is the
issue you are having.
If the cord does not work, then you will have to take your monitor into
a repair shop as there maybe an issue with the receiving port on the
monitor.
I hope this was helpful and thanks for asking the experts.
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
