SOURCE: Ignitors are igniting on their own
they are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
SOURCE: GE jp938 just quite. No response to any of the
ck the internal wiring under the top / it may have burned a wire end . make shure you have power on both lines ( 220 v ) m m
Testimonial: "Answer provided a clue in finding the problem. One side of the circuit was ded. Thanks"
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
SOURCE: My GE Profile JPG636 cooktop has an ignitor
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
SOURCE: ignitor does not click
there is no "ignitor" as you would find in an oven or dryer. There is a sparkmodule that many times goes bad after 5 to 8 years. It is a plastic box about 4 to 6 " x 2" wide and wil have 3 to 5 wires or 3 to 5 terminal connector points on it. remember to unplug the range top fromwall electric. these units are not difficult to replace; they are not repairable, you have to buy a new one.
