Watch stops with inactivity
SOURCE: Opening Bulova Casement
Take it to a local jewelery store and they will do it for about $15. Joe
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
SOURCE: I can't seem to remove
If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
SOURCE: I just had my battery replaced in my Bulova
You can get instructions from their web site by going to http://www.bulova.com/service/servicecenter.aspx and finding your watch in the list.
SOURCE: I cannot get the back of my Bulova watch back on.
Most Bulova Watches have PRESSURE TIGHT backs. Meaning the back is applied with EQUAL amounts of pressure to the entire back. There are two(2) solutions:
1. Take the Bulova watch to an experienced watch dealer/repaiman, to have the back applied, or
2. CAREFULLY MAKE SURE THE BACK IS IN THE PROPER POSITION, then WRAP THE ENTIRE watch with a soft, cushy clothe and with a pair of pliers, CAREFULLY apply pressure to the center of the back plate, until the back covers seats to the proper depth(closed), at the same time BEING VERY CAREFUL not to crack the watch crystal!!
