Even with new batteries, camera says change batteries. It powers up on the preview side mode for about half a second then goes off again.
Is the lens not coming out at all? did you check is the lens is blocked somehow?
When a mechanical problem occurs, this can be a trigger for the camera to shut down, before something becomes (more) damaged. Did something happen the last time you used the camera?
Was the camera switched of for a very long time?
SOURCE: A310 - Batteries Overheating - Will Not Power On
to make a battery hot some short circuit has to be there u can check it by connecting a wire to both ends of a battery and te battery will become hot in a minute . it is because when electrons get a easy wasy to travel from negative to positive it will travel in a great speed and due to this speed it will collide with other electrons and will make the battery or wire hot . this is the same principal of a fuse wire also when lot of current passes through a wire it gets hot and will be burned]] i think u have got the idea how a batter can get hot if u put the battery in the wrong side also this can happen to ur camera and if there is a short circuit or a wrong battery can also make it hot so check the manuel to find wich type of battery is needed for the camera
SOURCE: Shuts down while using the zoom lever
see this thread :
http://www.fixya.com/support/t225803-canon_powershot_s3_switches_off_when
SOURCE: Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
SOURCE: Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
SOURCE: CAMERA MESSAGE SD790 IS
Well, I haven't used a Canon PowerShot SD790 IS Digital Camera before, but I want to suggest this: before you start thinking of putting your camera apart, try to clean the battery terminals and the battery contacts of the camera with clean white paper, then reinsert the pack. Please be very careful when doing this so that you do not break or bend the contacts or terminals; they are usually delicate material.
