The convergence is off and when I go to crrect it manually, it won't work. The green + is not cnetered (at the 5 position) and I cannot get blue or red to meet with green. Others (1,3,4,6,7 and 9) are aligned okay. Any advice? Is it worth the maintenace of $400+ or get a new TV??? Thanks!
hi, i have the 56wp74, red was out of wack, i properly installed new ic's, and now the green is curved, the red and blue is out of wack too. i tried to manually adjust in the service screen, without luck. i tested all the resistors, and the only two that dont seem right are the 220 ohm on the r873 spot on the board, and the 150 ohm resistor on the r863 spot. both read 89ohms instead of what is on the resistor. could that be the problem, and where can i get thoes resistors?
Just the green is bending in and won't align.
