When I step on the pedal, it does not engage. Opened it held, down the black toggle switch and it does stay on then. Batteries are brand new.. Bought new 3/08. Have not used it a lot
Thank You, KenGib
I have seen a somewhat similar problem before. A switching diode had become faulty and needed replacement. I have no way of telling you where to look but if you have a volt ohm meter you can test them individually without removing them. The diode you are looking for would be in the circuit which connects to the switch. Use your probes to get a reading in one direction(one probe on each end of the diode) and then a reading with the probes reversed. If the readings are close or infinite in both directions you will want to unsolder the diode (making careful note of its orientation) and test it again. If the readings are still the same or close you will need to replace the diode. I forgot to mention to use the 2000 ohms resistance scale or the diode test function if you have one. Hope this helps.
http://www.bossus.com/backstage/product_...
Thank you, I looked through the Manual and found I had a "Hold"
mode on the pedal that was on. Also, I had the battery upside down!
This manual did not cme w/ my pedal. Thank you again!
KenGIb
i just bought new fender delay pedal, i put 9V battery on it and it's not working, only battery is hot
