This one i have has a different font for the S after the e815. the s is more rounded that some i have seen in pictures. They have a squared off S font
SOURCE: Motorola E815 alarm quit working
I've had a similar problem with alarms not going off. In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off. Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes. The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
SOURCE: Motorola E815 Display Screen Blank
Flex cable connected to the main board tend to get loose. You need cell technician to fix that problem.
SOURCE: motorola e815 CDMA cellular phone unlocking software free download
The Motorola E815 is a CDMA handset. CDMA (code division multiple access) is a digital service only provided in the United States. Unfortunately, CDMA handsets will only work on CDMA service. Therefore, the phone you are referring to cannot be used overseas.
GSM (Global System for Mobility) phones are the ones that can be unlocked to provision for different SIM cards. Once a GSM handset is unlocked, or "unbranded", it can be used with any GSM provider's SIM card.
Sorry for the bad news, but your E815 will not work in India.
Please rate as at least helpful, as there will be no Fixit solution for your situation.
SOURCE: Transfer my contacts from my Motorola e815
yes you can with the help of a usb data cable and motorola tools software, which you can download from motorola official website.
SOURCE: Unlock code on Motorola E815
By default the lock code on CDMA phones is the last 4 digits of the phone number so if you number was
555-555-0909
your lock code will be 0909 unless other wise changed, other than that the only way to get the code is trial and error.
