After the Eureka 4467 runs for a few minutes a power surge occurs. The vacuum motor slows down and any lights in the house are dimmed.
Is there a fuse or something that I can change?
The suction seems okay, and nothing is clogged.
Thanks for any info
Wow, thanks for the quick response! What is a "shorted turn in the motor windings", or how do I remedy this? Replace the motor? Replace a part in the motor?
Thanks for your helpWow, thanks for the quick response! What is a "shorted turn in the motor windings", or how do I remedy this? Replace the motor? Replace a part in the motor?
You can't post conmments that contain an email address.
If I am correct then a motor replacement or rewind would be required. The first course of action would be to take the vacuum cleaner to a domestic appliance engineer. Good luck!If I am correct then a motor replacement or rewind would be required.
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Leave it unplugged for a half hour then try it. But it sounds like it may have received a power surge or several. This could have fried the motor. The motor may have to be replaced.
make sure all your filters are clean,try to turn the brush roller by hand a few times if it turns real freely then the belt is broke.if it is reall hard to turn then you have something wrapped around the ends of the roller where the bearings are.your motor guard might be keeping it from running because it got too hot take the brush roller out and the belt let it cool down for 20 minutes then try it without the roller and belt.you should be able to take the ends of the roller off by just pulling out on them so you can remove what ever is in there
I would contact eureka for warranty repair. sounds like it there is something wrong with the mechanis of the unit. could be that water is making its way into the motor pump housing and causing damage to the pump
