Phillips Universal remote SRP2008b/86 will not operate my AWA DP239 DVD player even though there is an awa code listed.
Have entered the awa code several times to get remote to operate my awa DP239 DVD Player. After aperiod of time the remote simply shuts down. Same result when using the 999 code.
Most universal remotes have a list of codes for each make. If yours isn't listed, try using a manual search on the remote. It should have an instruction on how to do a manual search. If this doesn't work, look on eBay. There are hundreds of different universal remotes. Im sure you will find one specific to your brand and model.
I don't have other code for your DVD but I can give you the steps on how to program your remote to your DVD without the list of codes.
1. Turn on your DVD. 2. Press the DVD Mode Key. 3. Hold down SET on the URC for 2 seconds until the indicator lights up. 4. Enter 0005. The indicator should go out immediately. 5. Press the DVD Mode Key again as in step 2. 6. Hold down SET for 2 seconds until the indicator lights up and your URC is ready to start searching. 7. Aim the URC at your DVD, press the power key repeatedly, slowly until the DVD has been turned off. Once your DVD has been turned off, immediately press SET to lock in code and the indicator should go out.
Turn Off Player
Turn On Player
Tray Should be closed
Using the remote choose 'Setup'
Using the Left/Right Arrow Key select The 'Preferences' Tab
Key in 8737
You should see a Box with the current Region Code
Use the Down Arrow key to change it to 0 (assuming you want region free) or select another number for a specific region
Hit enter (the play key) to exit this menu
Turn player off
Turn player on
load Disc
put the code into the remote that relates to the brand (AWA) AWA is not a major brand and may be hard to find any code that works in it. I found 2 here that you can try 0753 or 0895 If either work, write them down on the DVD player do you can remember them next time
