Question about HP DeskJet 930c InkJet Printer
My 930c hp inkjet printer is printing a pinkish hue type color to it, but my black show's up with a pinkish hue outline to it, not sure what's going on..plz help...
  • samierae May 04, 2009
    yes i'm a girl...where do i find the tools button?
    Problem Solver:
  • 4 Answers
Change Color Code By Going To Tools Then Error Console Choose Your Color And Then No More Pink(Are You A Girl
Posted on May 04, 2009
6ya staff
SOURCE:
Why won't my HP 930c print colour when properties set to colour?
Check in printer properties., mught be you selected as print in gray scale or black & white., there select print in color mode..
Apr 29, 2015 | HP DeskJet 930c InkJet Printer
How can I make my HP 930c print with no color cartridge?
you cannot make it print with no cart, but if you have an old one, drill holes in the top and fill with water, 930c uses weight to establish ink level, after much mucking around I have done this today, printing right now :)
Mar 31, 2011 | HP DeskJet 930c InkJet Printer
Is there any way to disable the color cartridge in my HP 930c? I want to print only in black.
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print. Most HP printers need at both cartridges in the printer for it to print.
Jan 18, 2011 | HP DeskJet 930c InkJet Printer
Only printing in black after inserting new colour cartridge
If color is coming out gray then you may have grayscale selected in your print settings. If color is just missing, check to see if the tape on the back and bottom of the cartridge has been compelety removed. If that is not it then run the head cleaning. If that doesn't correct it, then you just got a bad cartridge.
Aug 31, 2010 | HP DeskJet 930c InkJet Printer
Orange cartridge light is flashing. I know the black cartridge is empty, but the colour cartridge is o.k. Why can't I print in colour?
Inkjet printers use a combination of inks to produce colors; while you may not realize it, your printer uses black ink to print colors as well, to darken the hue of a color. Otherwise, it would be limited to very "bright" colors. Replace the black cartridge, you will be fine.
Mar 05, 2010 | HP PSC 1350 All-In-One Thermal Printer
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP 930C will not print in color
Have you made sure that the plastic strip covering the cartridge is removed? Also, are both of the cartridges installed? Mine won't print if both aren't installed. Next, you might want to check that (in printer settings) your printer isn't configured to print pure black/greyscale. Otherwise, check the HP Site, they have walkthrough guides on how to print tests directly from your printer. Hope this helps. BurntLime
Dec 16, 2008 | HP DeskJet 930c InkJet Printer
HP printer using color for printing black text
I have solved this issue on other printers by going to the Control Panel, clicking on Printers and Faxes and right click on the printer icon and select Printing Preferences. Most will have the option in the basic or advanced view to select black ink only, this may also be an option in the Paper/Quality tab.
Oct 18, 2008 | HP DeskJet 930c InkJet Printer
No color
Make it sure that ink cartridge are genuine not generic , sometime the generic ink the printer connot identify because the small chip at the back of cartridge are defferent from genuine ink.Sometime the generic can print but not true color, genuine has a perfect color and you will satified save time , money ,and effort.
Dec 20, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP DeskJet 930c InkJet Printer Logo
345 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
