Nabi 2 Logo
l
linda rhoten Posted on Nov 14, 2013
The tablet got wet - Nabi 2
My kindle got wet and the screen is frozen on the home screen What do I do ?
My kindle tablet and my fire 10 tablet have water damage Help!
What can I do about my daughters tablet getting wet and won't turn on??please help!!
If the tablet got wet and you tried to turn it on wet, it won't turn on ever. It's done...
Don't lose hope, take it to some repair service but don't have much expectations.
For the future, remember NEVER turn on a wet electronic device
I got it wet help
just wet - no problems. But if you got it drowned then that's a problem: the cheapest way is to replace it.
For wet device: put it into closed box (remove battery first) with a lot of salt around (keep the salt from the device though) for a day.
Nosound from earphones onGalaxzy 4 tablot
what did you clean them with ? water?, bad move. you should only clean your electronics with acceptable electronic cleaning solutions,
or Rubbing Alcohol on a lint free wipe very lightly saturated then swing the cloth around in the air for a few second to make sure its not dripping wet, but very lightly damp. then make sure all units are off with no current flowing through. also make sure that you DO NOT turn them on straight after let them dry completely. ( when applied to items should see a streaking not an overall wetness.(if overall wet, you've used to much) drying time is based on wetness.) Use hair dryer if necessary.
Good Luck, try the dryer on the headphones. including the tablet plug in area. you might have gotten water in it.too!
1helpful
Wet tablet
Put it in a large bowl. Then add rice. Rice has a habit of soaking up water. After a few days try your luck and turn it on.
Ipad got wet turn after dry now what can i do?
Lines on the screen indicate motherboard issues. You should be able to use it for a while longer, but the motherboard will likely fail. You could attempt trying to get it repaired if it is under warranty, but as it is water damage it might not be covered.
1helpful
Keyboard Jiberish
It could also be the logic board. Usually, there are weep / drainage holes in the bottom of the laptop. See if there's any traces of moisture there, and you'll know if it got wet or not.
Sounds like it could have been wet. You could try replacing the keyboard.
Top Nabi Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
techy
Level 1 Expert
Ari Garcia
Ari Garcia
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
