Sony Walkman Video NWZ-A815 Digital Media Player Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Playlists i am trying to put a playlist to my walkman but i cant can u tech me how
Anonymous
Level 2:
  • Expert 59 Answers
  • Posted on May 04, 2009
Anonymous
Expert
Level 2:
Answers
59
Questions
0
Helped
18182
Points
125
Try converting your music to .mp3 files for movie mp4 format hope it helped message me if you have any concerns.
I have a Sony Walkman Atrac AD and cannot make playlists with it. There is the option, but how do i put music on them?
The only way to add playlists on this unit is to use your PC software to create them and then add to the unit later. you cannot create a playlist on the player itself.
you can use any music software to create and add. for instance, If you are using Sonys own Soundstage, follow these instructions:
Click "My Library"
Click "create/edit PLaylist"
Select the tracks you want from content shown on left. ( to select multiple tracks at once, hold CTRL key)
Select the "New Playlist" on right
The new playlist will be created. you can rename it now
click on large arrow pointing left
Now just import this folder to your player
you are done.
Here is a link to the user guide
http://www.docs.sony.com/release/NWHD5_english.pdf
Thanks
Please rate FIXYA
How to erase the playlist?
For erasing the Playlists from the Player, you've to use the same Software which you've used to transfer the Playlists. The steps on deleting the Playlists depends on the Software used for transferring. Please go through the HELP files in the Software for the information on deleting the songs.
Good Luck! FixYa
2answers
3helpful
2answers
I cannot figure out how to make playlists and store them on my Sony mp3 player. I have workout music and study music and I cannot figure out how to make them so I can listen to the playlists separately.
The easiest way (though tedious when you start) I found was to just sync all my music, etc. through Window Media Player, then open the Walkman in Windows Explorer. Open the music folder and create a file for the music you want on the playlist. Copy all the songs you want the select the songs in the file, right click and create a playlist. Double-click on the playlist and put them in the order you want them. Click OK. Whan you disconnect the walkman, your playlist will be there. This is the only way I have found to actually have my playlist show up in the Playlist feature on my Walkman in the order I want the songs.
1helpful
2answers
Makeing playlist
go to windows media player then the sync tab then click on the word playlists then drag desired playlists to the place u put the stuff u want on your mp3 player and click start sync.
10helpful
2answers
Making playlists on my sony walkman mp3 player
OK so it is a little confusing on how to create a playlist, I am about to make your headaches go away on this issue.
1.Plug your mp3 player into your computer. 2.Go to my computer and open your mp3 player in windows. 3.go to your folder on your mp3 player that you have files folders etc.. that you would like to add to a playlist. 4.right click on folder and choose "create playlist" 5.Name your playlist.
thats it ! you should now have a playlist on your MP3 player, I hope this helps.
Sony NWZ-S616F playlist problem
to add files to walkman i open the walkman icon that appears when i connect to pc an find and open folder named songs....drag and drop your song files ( as mp3) and thats all
hope this helps
1helpful
Playlist on computer, but not on walkman playlist
Possibly wrong format make sure its in MP3 or WMA format i know MP3s work well ive never tried WMA but thats another format people use
62helpful
13answers
Cant transfer a playlist to my sony mp3 player
Windows Media Player (WMP) 11 in XP does not create Playlist on my MP3 MTP device. I have a Sony Walkman NWZ-S544 but I think my problem and its solution could also apply to other MP3 players that don't receive Playlists from WMP. And perhaps to Vista and Windows 7?
When I connected my WALKMAN to my PC and used WMP to Sync (transfer) Playlists to it, the songs were correctly Synched but no Playlists were created on my WALKMAN. My problem was that Windows had installed the wrong driver for my WALKMAN. Here is how I diagnosed and fixed the problem.
DIAGNOSIS: When I used WMP to Sync, the picture in WMP's right hand window was a generic MP3 device. It should have looked like my WALKMAN NWZ-S544. When I looked at the device drivers, I couldn't find a driver for my WALKMAN NWZ-S544 under Portable Devices, but instead found a non-MTP Walkman listed as a USB Mass Storage Device. (See Fix explanation for how to look at device drivers.)
Fix: To fix the problem I first uninstalled the incorrect driver and then installed the correct driver. Here's how…
  1. I disconnected all MP3 players and USB devices (Key/thumb/External Hard drives, etc) from my PC.
  2. I opened the Device Manager. Right-click My Computer-Click Properties.-Click Hardware Tab-Click Device Manager. No Portable Devices were showing. Click the + to the left of the Universal Serial Bus Controllers heading and there was one USB Mass Storage Device but it was for an irrelevant memory card reader on my PC that I can't disconnect.
  3. I connected my Walkman. Looking at the Device Manager, I see that one new USB Mass Storage Device is now showing, I right click-Properties and it describes it as a Compatible USB storage device (Walkman). This is my problem. Windows is using an older Walkman driver. My Walkman driver should be for a MTP device.
  4. I again right click the Walkman USB storage device and click Uninstall. I click OK to Confirm Device Removal. The Device Manage no longer shows my Walkman which has now turned itself off.
  5. I disconnect my Walkman and then reconnect it. Windows gives me the message that I have installed new hardware. The Found New Hardware Wizard starts. I click "No, not this time" and then Next. I click "Install from a list or specific location (Advanced)" and then Next. I click "Don't search. I will chose the driver to install." and then Next. I click "Show compatible hardware" and I select "MTP Device" under Model and then Next. Windows then finds the appropriate driver for my Walkman and I'm done.
VERIFICATION: To verify that it is properly installed, look in the Device Manager under Portable Devices (while your Walkman is connected). Click + and you should see:"Walkman NWZ-S544". Or simply look under Name in My Computer and you should see an entry for Walkman NWZ-S544, and an icon that looks like your Walkman. Everything should now work properly.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
