Red led light blinking 6 times
SOURCE: 6 red light blinks-possible thermal fuse prob.
You need the location of the part that's stamped on the board near where it was soldered in. And you need a soldering tool to resolder the new part in and cut the excess wire with cutters so you're not to short out the circuit.
C-Dog
SOURCE: 6 red blinks
Hello MCMECH,
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit:
1-576-912-11 Average cost $8.00 You can purchase it directly from http://www.partstore.com/GetModel.aspx?MfgName=Sony&BrandName=Sony&ModelNumber=KDFE42A10&PartCategoryName=&Keywords=%091-576-912-11+&x=18&y=14
Best regards
Circuitcity
SOURCE: sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
