Bosch 30 in. NGP 732 / 736 Gas Cooktop Logo
A
Anonymous Posted on Nov 14, 2013
Cannon c60gpxf clicking igniters continues after oven is lit
Gas burner continues clicking after on and flame active.
many ovens are made to click like that and nothing is wrong with burner oven, its a safety measure to let you know gas is on or escaping. I f you turn the knob bac or forward a little bit it will go off and flame will still burn. Other words you may have a dirty spark igniter , see pics
My igniters continue to click after the burners are already lit. Is this a problem? What can I do about it?
The sliding mechanism that works the igniters is getting stuck. Remove top and Clean out the moving parts from yucky grease, etc and all will be fine. The springs will return the igniter to default off position.
Sep 22, 2017 • Cooktops
I have a Miele cooktop and often during ccoking another burner starts clicking and click for a long time......solutions..... Also the lower left burner goes on for may be 10 seconds while clicking, the...
I have the Miele km342g cooktop. The ignition would continue firing intermittently after the burner was lit - click, click, click. Drove us crazy for years and we cursed the unit every time we used it. We assumed it was sensing unburned fumes and so we bought a small fan to "whisk" the gas fumes away. etc. etc. I finally figured out what a simple little thing it was. To start the burner, you turn the knob counter-clockwise. Therefore, once the burner is lit it's intuitive to turn the burner down by turning it clockwise. But in order to turn the burner down, you have to continue turning it counter-clockwise - or, "counter-intuitive". Once we figured that out, we haven't had a problem since.
3helpful
2answers
The ignition - clicking - continues after burner has lit - all 5 burners have this issued
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 • GE Cooktops
10helpful
2answers
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 • Cooktops
6helpful
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 • Cooktops
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
