8 times flash denotes a fault with its T'Con board. Check the connecitons to T'Con. To
get more details, http://electronicshelponline.blogspot.com/ Blinking codes to Sony LCD TVs are given in detail.
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
does it flash say 8 times then a little break then flash again 8 times or 9 or 10 . The flashes are giving the type of fault you have. Say 3 flashes then a tiny break then 3 flashes and a tiny break so on...
? I wounder what color is your lamp - red or yellow (amber) and just so you know most parts stores now days can tell what a code is with out charging a dime to you.
High Voltage Splitter Block #8-598-955-32 8 Blinks Call MAT electronics 1-800-628-1118 or Electronix Parts 1-800-223-3205 or you can go to thier websites online.
