SOURCE: motor worm gear hobat a200
Harry, if you're confident that you can take it apart and repair it yourself, then do the following. Go to www.hobartservice.com website. Register, and when you've been admitted to the site find the discontinued products section on the left hand side of the page, click on it, then select the Food Machines Group, then select Mixers. Make sure that your ML# is covered by the document.Select the file numbered A-200 Parts List F-6728. pdf. Look for the ML#. Once you've selected the document, go to page #9, there you'll find the exploded drawings for the A 200 transmission parts. If you look at the whole document (15 pages), you should be able to see what needs to be taken apart to get at the worm gear.
If you're not sure you can do this...Then don't do it. But if you do, check all bearings, springs and gears for excessive wear and replace as necessary. Hobart techs do this stuff every day. For someone who has not done this kind of rebuilding before, it can be a long and expensive learning curve. Good luck. If you find that this solution has been helpfull to you, please rate it. ricardok45
SOURCE: hobart A200 mixer motor worm gear
sometimes you read of other problems and solutions and it puts you at the edge of your seat. in this case of changing the worm gear on the A200F was cake. when you drop the lower end (3/4 acorn and jam nut), pull out yoke (speed select handle) the center transmision shaft and gears pull right out.worm gear easy to change at this point. if you can change a motor bearing, then you can do this job. Note: change seals and bearings as needed,check all gears,keys and spacers for wear and if you go the mile take gears off drive gears, these are the 2 smaller trans shafts put in lath if you have accsess to one if not roll shafts on flat surface to see that shafts have no bends in them. Also remember when you put the bottom back do not over tighten the jam nut,hold and lock acorn nut, should spin free and have about .016 to .030 movement up or down. Lay out all part on cardboard the way they came out. should go back together easy.
Harry Ooooooooooo
SOURCE: Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
SOURCE: on and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
SOURCE: worm gear hobart slicer
the gear has a cover cap - pryed up with a pin or needle, a screw is beneath, easy removal - getting a replacement gear is a proiblem
