Roper REX4634KQ Electric Dryer Logo
A
Anonymous Posted on Nov 14, 2013
Part number for heating element Roper RED444OVQ1
Heating element
5 Related Answers
Anonymous
  • 550 Answers
  • Posted on Aug 27, 2008
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Anonymous
  • 5 Answers
  • Posted on Aug 28, 2008
SOURCE: no heat
There is a cheap way you can fix this which I have been doing you years!! Yes i said years... First of all the heater elements are expensive so what i did is opened up the back and found the heater element and un screwed it. you see a bunch of springs and you will see that there is a break in the spring. all you need to di is overlap the spring and replace back in. Now replace the back shield and connect back the hose. and plug in. Now each time i do this it last for about a month as long as you don't over fill the dryer. NOW THE DANGEROUS PART! I have had to do this so many times that i no longer put the shield back on so i can easily get back to the element and patch it which does leave me open to lint getting into the coils and burning up..... This has never happened be aware of this. THE BEST THING I EVER DID FOR THIS DRYER IS TAKE A BLOWER AND BLOW FAST AIR INTO THE HOLE IN THE WALL AND THIS HELPED SO MUCH!! THERE WAS A LINT STORM IN THE NEIGHBORHOOD BUT THIS HELPED A LOT!!!!!!!!!!!!!!!!!!!!!!
*** UNPLUG THE DRYER BEFORE ATTEMPTING *** PLEASE
remember it would be bad business to make the element last forever but you can extend the life for years doing this!!
Anonymous
  • 311 Answers
  • Posted on Jan 01, 2009
SOURCE: warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Anonymous
  • 43501 Answers
  • Posted on Jan 20, 2011
SOURCE: I have a Roper dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Anonymous
  • 61 Answers
  • Posted on Feb 22, 2012
SOURCE: have a roper dryer model red444ovq1 that will not start. have checked door switch element,thermofuse,cycling thermostat high limit fuse the 249 volt circuit and every thing else that would normally ca
BE SHUR TO CK FOR 240 VOLT UNDER A LOUD PUT YOUR LEED ON LINE 1 AND LIND 2 AND PUSH STAR TO SEE IF THE 240 STAY. IF YES THEN YOU CK THE FUSE FOR CONTENUTRY AFTHER TAKING 1 WIRE OFF IF YES CK TO SEE IF YOU GET 120 VOLT TO THE MOTOR ON WAITE WIRE AND BLK OR BLUE IF YES THE MOTOR IS OUT IF NOT THE CK TIMER .
Testimonial: "thanks ver much. "
Dryer heating element are they interchangeable
The elements are usually not interchangeable. You can use a website like appliance parts pro to look up both units by model number to see what the elements look like. They usually have diffferent mounting hardware or the enclosure might be different, some mount to the back wall and others mount underneath the drum.
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Roper dryer not heating
Could be a number of things. A fuse kit, an element, a burned wire, faulty home electrical outlet or breaker, bad motor (rare). I would check for continuity on the fuses and element first.
1helpful
Have a roper dryer model red444ovq1 that will not start. have checked door switch element,thermofuse,cycling thermostat high limit fuse the 249 volt circuit and every thing else that would normally ca
I have a Roper dryer Model: RED444OVQ1 that won't turn on .
Dryer Repair - The
Dryer Repair - The
heatman101
5helpful
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
How do I replace a heating element in a Roper clothes dryer? I get no resistance across the element with my ohm meter so I assume the element has been broken or burned in two. I can not find a way to...
I am not really familiar with your particular model number but most roper dryers have the heating element in a thin metal housing that is rectangular. The housing is part of the heating element and comes with the new one. Usually you just take the screws out of the outside of the housing and it comes right out. I hope this helps.
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Warm heat..clothes not drying
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
