JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Nov 14, 2013
How do i exit chromecast and get back to tv - JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
How do i cast my acer chromebook r11 to tv
Use Chromecast with your Chromebook
You can view your favorite videos, photos, and websites on your TV using Chromecast.
Before you set up
For Chromecast to work on your Chromebook, you'll need:
Set up Chromecast with your Chromebook
  1. Turn on your TV.
  2. Plug in your Chromecast. Learn how to plug your Chromecast in to your TV.
  3. Using the Input or Source button on your TV remote, change the input on your TV until you see the Chromecast home screen.
  4. On your Chromebook, sign in to your account.
  5. Follow the steps that show on your TV. Learn how to set up Chromecast.
I would like to stream from my tablet to my TV
Buy a small gadget called a Google Chromecast. Attach it to the back of your tv then download the Chromecast App onto your tablet. You can get the full set of instructions on YouTube.
HDMI input not working - TV is 4 months old
Unplug TV from mains power and leave for a few minutes before plugging back in. Then try the HDMI again.
Hooked up to netflix to phone and TV yesterday and all worked fine. Today tried it and it won't play on the TV will only play on the phone. How do we fix
Google Chromecast HDMI Streaming Media Player (2014 ...
www.walmart.com/...Chromecast-HDMI-Streaming-Media-Play...
Walmart
Rating: 4 - ‎1,760 votes
Buy Google Chromecast HDMI Streaming Media Player (2014 Model) at ... This plug-and-play media player allows you to cast your favorites from Netflix, ... It automatically updates to work with a growing number of apps. ..... I love not having to put my laptop next to the tv and hooking up hdmi cords to play .... Mobile apps.
Google Chromecast: What Is It and How Do You Use It ...
techforluddites.com/google-chromecast-what-is-it-and-how-do-you-use-it/
Dec 16, 2015 - The Google Chromecast is a streaming media player, which means it... But there are many other top content providers that work with it as well, includingNetflix, Hulu, .... and use your television remote (NOT your Roku remote) to switch to that ... I set mine up using the Chromecast app on my Android phone.
5 Easy Ways to Get Netflix & Other Video Streaming ...
www.techlicious.com/.../5-easy-ways-to-get-netflix-video-streaming-serv...
Feb 27, 2015 - For laptops, just plug it into your TV with an HDMI cable. ... GoogleChromecast to top-of-the-line Roku 3, Apple TV, and Amazon Fire TV. ... To decide which one is best for you, you'll want to not only look at the features on offer, but to also ... Here are the best streaming media players on the market today.
How to set up a Chromecast - CNET
1helpful
How do I connect a chromecast to WiFi
This page should help, but it is not in the best order.
1. Download chrome browser on your pc or tablet, cellphone as chromecast will only talk to this browser.
2. Download the chromecast app and install it on the computing device.
3. Search for a program the chromcast device on the same wireless network, you need to use the power supply provided and plug it into the TV.
4. Setup the chromecast device.
5. Now set up the TV side of things by selecting the USB or HDMI connection.
6. Now it should connect to the Internet, if doesn't check your router is letting it pass through to the internet.
Chromecast manual Chromecast setup guide All About Chromecast
Will chromecast work with my dell d830 ?
Hi Michael,
You do not plug Chromecast into your laptop HDMI port, it is a video source, so you need to plug it into an HDMI port on your TV. Your TV is an HDMI target, the view side.
If you can run Chrome browser on your laptop, you can cast from your laptop to your Chromecast device and watch that frame on your TV.
Does that make sense? Have a look at the link below for more info.
Plug In Chromecast
Will chromecast work with compaq cq60-615dx
Chromecast is connected to the TV and not to your computer. Your TV should have free HDMI port to connect the Chromecast.
You should WiFi configured and both chromecast and you computer ( you can use wired connection for PC) should be connected to the same network (router).
2helpful
Can Chromecast damage TV? I recently bought a Chromecast and it worked fine. Then the picture disappeared, but I still had sound. Today I reconnected it to test it, and one hour later I have no sound
It won't damage the TV. Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Type in the brand name of your device, in the search box at the display window, and press enter to get all related posts. It will make surf easy.
My chrome cast screen is stuck showing the 100% sign with a circle moving around it
Sounds like it got stuck doing an update. Cycle the power on the chromecast. Unplug the chromecast and re plug it in.
Scrambled screen
Hi, this could be a power issue, are you using a USB port on the TV to power the Chromecast?
Some older USB ports might not have enough power capacity in which case you should use the small power adaptor that came with your Chromecast and power it from a wall socket.
Hope this helps!
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
