On the memory card their is a switch that locks and unlocks the card,i unlocked the card,but my camera still says protect card.
Check if in the card slot is any debris. You could try to clean the contacts of the xD memory card with a dry cloth. Place the card on a flat underground and press firmly on the cloth. Don't press without a flat underground, because you could easy break the card.
It also could be some of your pictures are protected. You have to unprotect the pictures first.
SOURCE: card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
SOURCE: My memory card in my camera keeps saying its protected
Hi there, My name is Rob and I can help you. Do this:
Make sure the camera is off and pull out the SD card. Look on the side of the card. You will see a little switch. One side says locked (or shows a little picture of a locked lock) the other side says unlocked (or shows a little picture of an unlocked lock). Make sure the switch is in the unlocked position and reinsert it properly into the camera.
This will fix your problem. Thanks for coming to FixYa. Let me know if I can be of anymore help. Don't forget to rate my answer a fixya!
Rob
SOURCE: my DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
SOURCE: have fujifilm finepix f40fd. protected card shows. wont clear
just take out the memory card . there will be a small button or a panel like thing on one of its side. just move that to the other side i.e opposite to the current position of the button. re-insert the memory card and check it out...
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
