Get a handkerchief, any color. Place watch inside said handkerchief and with a 2ound hammer smash the snot out of it. After that, go to WAL*MART and buy a watch without an hourly chime.
Question edited for clarity and toss in some CAPS.
Question moved from Reizen Phone to Resizen Watch.
Hourly Chime Announcement On and Off.
Hourly Announcement (Chime) ON/OFF
(When Chime is ON, the watch announces the HOUR every Hour)
Hold the 8 o'clock button while the watch is in the real time mode for more than 5 seconds until the watch says "Set alarm, Press 10 o'clock button to set."
Push 8 o'clock button 2 more times, until the watch says "Chime ON/OFF, Press 10 o'clock button to set."
Press the 10 o'clock button.
The watch says, "Press 2 o'clock button to turn ON, 4 o'clock button to turn OFF, 8 o'clock button to confirm.
To turn OFF a Chime Alert, Press 4 o'clock button. To turn ON a Chime Alert, Press 2 o'clock button.
Press 8 o'clock button to confirm.
After a Chime alert is turned ON, the watch will announce the HOUR every one hour.
most chiming clocks only chime on the hour from 6 am to 9 pm
if it is a digital clock with a chimer the set it to 12 hour and not 24 hour
make sure that the chime has a good battery in the chime circuit and it is set to chime on the correct hour
If the statement made to you was correct then it would be chiming at night instead of the day
When you are setting alarm, there will be visible sign of loudspeaker or bell. Toggle with buttons and when the sign is visible in normal mode (ordinary time showing mode - everyday wear) the beep will alert you every hour. Be aware - there are hundreds of people asking how to disable this function, simply because it gets annoying after a few days - it works during the night time as well.
I would like to let you know that each firewall has its own level of protection. We cannot really identify the level of the firewall protection in your school. Each level has its own set of tweaks to use for you to bypass its protection. Though, it's not advisable to use yahoo during classes hours I really want to share this to you... Try http://grapesnake.com/ it's a website which can bypass most of the firewalls. But, we don't know if this will work in that certain firewall.
I hope this helps. Remember, I am giving this to you for some good reasons not because I want you to bypass the school's firewall and do nothing during classes hours. I hope this helps.
Press the bottom right button and while holding it down press the bottom left. All the days will show and the hourly chime is off, if the days aren't lit the hourly chime is off.
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever. 1) "Night On" - This will keep the chime striking 24 hours 2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM 3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
