2000 Jeep Cherokee Fender Logo
j
jim mincher Posted on Nov 15, 2013
How to remove front fender - 2000 Jeep Cherokee Fender
Cerveza Torres
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Nov 21, 2013
Cerveza Torres
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
6866
Points
36
Open the hood, look for the bolts that hold the fender to the frame of the car, remove all of those. Then look under the fender behind the tire, remove the plastic pins holding the splash guards to the fender and remove the guards and any plastic trim attached to the fender. Look for more bolts and remove them. Remove the fender carefully.
1helpful
How do I replace my passengers side fender on a 2012 dodge durango
REMOVAL Hope this helps?
Labor Operations: Click to display a list of Labor Operations associated with this procedure
  1. Mark fender location.
  2. Remove wheel if necessary.
  3. Remove wheel liner.
  4. Remove front fascia as necessary, (Refer to 13 - Frame and Bumpers/Bumpers/FASCIA, Front - Removal) .
  5. Remove front lower mounting bolts.
  6. Loosen rocker panel cover as necessary.
  7. Remove rear lower mounting bolts.
  8. Remove upper fender mounting bolts.
  9. Remove fender from vehicle.
How do you remove the driver side front fender on a 92 chevrolet s10 pickup?
remove the driver side front fender Teeta, Removing fender on your truck, Check the attached links,instruction and guides may be not identical but really close to yours. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1994 to 2003 Chevy 10 GMC 15 Blazer and Jimmy Left Front Fender...
http://www.s10forum.com/forum/f137/s10-fender-removal-457021
http://www.automotiveforums.com/t561502-need_help_on_removal_of_front_fender_my_91_s10_blazer.html
S10 Fender Removal eHow
Where is the horn location under hood of a 2007 mercury mountneer?
Remove the LH front fender splash shield !
Fender Splash Shield Removal and Installation
  1. Loosen the running board bolts and lower the running board to access the front fender moulding pin-type retainer.
    • To install, tighten to 23 Nm (17 lb-ft).
  1. Remove the lower pin-type retainer from the front fender moulding.
  1. Remove the 2 rear pin-type retainers from the front fender moulding.
  1. Position the front fender moulding aside and remove the splash shield lower screw.
  1. Remove the front splash shield screws.
  1. Remove the front splash shield pin-type retainers.
  1. Remove the front splash shield.
  1. Remove the front fender splash shield.
  1. To install, reverse the removal procedure.
How change front fender f150 2000
Fender -Front Removal
  1. Remove the radiator grille opening panel reinforcement (8A284).
  1. If equipped, remove the front wheel opening moulding.
    1. Remove the pin-type retainer.
    1. Remove the screws.
    1. Remove the wheel opening moulding.
  1. Remove the front fender splash shield (16103).
    1. Remove the pin-type retainers.
  1. Remove the cowl grille.
  1. On RH front fender, remove the antenna mast.
  1. On RH front fender, remove the antenna base.
    1. Remove the radio antenna base cap (18A927) by gently inserting a thin straight-edged screwdriver underneath the cap and carefully following inside the perimeter until both snaps are free.
    1. Lift the antenna base.
    1. Disconnect the radio antenna lead-in cable (18812) and remove the antenna base.
  1. Remove the fender stuffer.
  1. Remove the stone guard.
  1. Remove the front fender.
    • Remove the bolts.
1helpful
Trying to remove the battery from my 2007 soltice
Hello robert.... Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Joe
Thanks for choosing Fixya!
4helpful
Where is the battery located?
Battery Replacement
Removal Procedure
Lower the vehicle.
Remove the battery.
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure . 1737d1122299169-solstice-service-battery-replacement-procedures-158wilmingtoncarshow36.jpg
hope this helps . please rate my response.
1helpful
Step by step proceedure to remove rear fender from 2000 fxdwg
1. Follow the taillight and rear turn signal wire harness to the 8-pin connector under the seat. Separate the connector. Remove the seven wires and the attached socket terminals from the connector.
2. Cut the cable strap from around the harness in front of grommet in the fender. Pull harness thru grommet in fender.
3. Remove (from underside front of fender) screw and washer from speednut on frame.
4. Remove turn signal lamps.
5. Remove screws and washers from rear of fender supports.
6. Remove license plate bracket.
7. Remove screws and washers from front of fender supports.
How you take off the front bumber
have 96, 95 similar
Section 01-19: Bumpers 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Bumper and Bumper Cover Front
Removal
  1. Raise and support the vehicle.
  1. Remove the RH and LH front wheel (1007).
  1. Remove the RH and LH front fender splash shield screws. Remove the RH and LH front fender splash shields (16102).
  1. Remove the four front fender brace screws.
  1. Remove the two front fender brace nuts.
  1. Remove the two plastic screws.
  1. Remove the seven clip buttons located under the front bumper cover (17D957).
  1. Remove the RH and LH front turn signal lamps (13369). Refer to Section 17-01 for the removal procedure.
  1. Remove the four front bumper cover brace bolts.
  1. Remove the front bumper cover from the vehicle.
  1. Remove the two front turn signal lamp wire harnesses from the front bumper (17757).
  2. Remove the eight front bumper bolts.
  1. Remove the front bumper from the vehicle.
11helpful
2answers
Dead battery
Removal Procedure
Remove the battery.
5helpful
Replacing the Right Front Fender on a 1999 Mazda 626
Can you remove the wheel well splash shield and get access to the bolts? Body shop techs have a special tool to get into this area.
Here's a 97 Probe whcih was the same as a 626 in 1997:
Fender, Front Removal
  1. On GT models, remove the side sill extension. Refer to Section 01-08 for the removal and installation procedure.
  1. Remove the front fender bolt located in the door jamb opening.
    RH Side Shown, LH Side Similar
  1. Remove the three upper front fender bolts located on top of the front fender (16005) inside the engine compartment.
  1. Remove the wheel (1007).
  1. Remove one push pin and five front fender splash shield bolts and remove the front fender splash shield (16102).
  1. Remove the upper front fender brace screw.
  1. Remove the inner front fender bolt.
  1. Remove the screw holding the front bumper cover (17D957) to the front fender.
  1. Remove the two lower front fender bolts.
Installation
To install, reverse the removal procedure. Tighten the front fender bolts to 7-9 Nm (61-86 lb-in).
Top Replacement Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Replacement Vehicle Part and Accessory Expert? Answer questions, earn points and help others
