Have a Magtag Front Load Model mah5500bww. When we start the cycle on regular cycle / hot/cold the cold valve opens fro approximately 11 seconds then all of a sudden it sounds like the hot water valve opens but I hear a bang and nothing. We don't get ant hot water. If I set the washer back to cold/cold the water comes back on. I just replaced the water valves. What could be the problem?
SOURCE: maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
SOURCE: Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
