I have nokia 7360 not charging, and i have checked the charger and the charging port intrerface, its seems to its like the problem is from bord. please help me the diagram to fix this problem. thanks
Just try to use othr charger..this will clear taht the problem is of charger or the charger port..most probably the problem is with the charger port of ur hndset. so get it checked from nokia centre.
1.Firstly Activate your 3G/GPRS facility 2.Get the GPRS setting manually or though customer care and install it. 3. For PC connecting Install NOKIA PC suite first 4.Then through USB connector connect to the port provided 5.When it is connected then go to profile/connection setting,create or select the profile provided and make it as default. 6.Finally connect it and enjoy you surfing.
first,check if your 5530 charging port.see if the gold needle in the hole is still there.if it wasn't there anymore then you need to replace the charging port which doesn't cost much money (may vary depending on your location). otherwise,try charging your phone with different charger because maybe the problem is from your charger too. the other probability is your battery unit is damaged,replaced it. if it's still persist,your IC needs to be checked. consult your trusty Nokia technician. Hope this will help.
Hi, when a phone does not charge, Usually is either from the charger or the charging port of the phone that is bad.
Use the charger on another nokia phone to see if it will charge. If it does charge on another phone, that means the charger is working,but the charging port is not.The charging port is located below the phone where the charger is been inserted.
It"s very easy to replace.when you unscrew the phone,remove the phone board,the charging port is removable,just buy another charging port,and replace and you are done.
I advice you try use a similar charger to charge your phone, if the problem still persist, i mean if the similar charger did not charge the phone, it means the charging port of your phone is bad and will need to be replace, i advice you replace the charging port of your phone if no charger charges the phone, replacing the charging port will help and get your phone charging.
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
My problem is similar. The phone starts charging and after a few seconds(like 20 or so) it says not charging. What could it be?
Jacques Atambo
pagsaksak ko po ng charger,, automatic not charging the respones, plz help me this problem, thanks,
