You have a short circuit on one of the other boards this is causing the power board to try and start thus the clicking sound,try unplugging each of the other boards one at a time and switching on till the clicking stops this should indicate which board is suspect.
Power supply board have problems.It dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sounds like your tube is out. To fix it would cost more than the TV. Try to unplug it overnight and try agian. Post again when you try that and we can try something else.
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Hey John, I am experiencing a very similar problem. If I unplug the TV when it is on (green light) and plug it back in. It begins green, and clicks to red. I immediately turn the TV back on with the remote. Most of the time it seems to struggle for several seconds, sometimes with a little scratchy audio popping in and out. It will then go from green to red on the TV and if I try to turn it back on it will go green for a few seconds and back to red but without any click coming from the TV. No matter how many times I try after that, no TV. If, on the other hand, I unplug while green, plug it back in and with the remote turn it back on after it has come up green and then clicked to red, it will come on. It might take thee or five times but at least it comes on... If you hear of a real solution, please let me know ([email protected]) in the meantime, best of luck.
Requires troubleshoot,locate and replace bad caps in horiz
drive circuit. Usually 47mf/25v..................+ solder any/all
bad connects = prevent maintenance................T.
