My 8400 Phaser has sat for many months in the office. Just tried to fire it up again, and every page jams near the metallic drum, smearing the output and leaving residue on the metal drum. I'm wondering if there's an easy fix for paper transport problems such as cleaning rubber wheels or whatever, or if this thing likely needs major work.
Hi david i hope i can help you? you may need to give the machine a good clean, if there is any rubber wheeles? give them a clean with meths. little rollers check to see if any carbon brown in colour. its caused by constant use. i hope this has helped you? top tip you must make sure all the brown is completly away. to make your machine run better.
