Came with no instruction manual, users manual
SOURCE: cd rw/dvd combo drive GCC-4242N WRITING PROBLEM
what brand , model number, and operating system you are using,,,
SOURCE: When I try to play DVD, nothing happens.
change the lens of DVD. its a common problem. due to over use.
SOURCE: My LG combo drive HL-DT-ST RW/DVD GCC-H23Ndoes not
The lens for reading dvd is busted and needs to be replaced that is why it no longer read dvd.
SOURCE: USB DVD drive slow booting
Hi friend,
You need to click on MY COMPUTER option and click on propertise then click on advanced ..then go to startup and recovery option. then change the system recovery option time...you can select 1 sec...
SOURCE: usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
