Amana lwa90al washer, need to replace seal at the bottom of tub. When I removed the bleach dispensor, I don't see how to remove the aggitator. I don't see a bolt or nut to remove it. Thanks, Dave
  • 3,741 Answers
6ya staff
SOURCE:
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
How do i remove the aggitator in ge wash machine
regular ge washers just pull straight up. harmonys are lg's though.
Sep 17, 2012 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
My Amana NAV2330AWW (S/N12279742EP) has been in service for six years. It has begun making a loud squealing, friction-like noise at the spin cycle. I removed the agitator assembly after being told it...
Firstly i want to apoligize for the quesionable advice,some on here or elsewhere on the net fixed their washer and suddenly their are experts!!
Now Then as you know your washer is made by Amana/Speed Queen and has no agitator dogs(a quick search of parts breakdown will show anybody that) it also has no spin tube (aka basket drive),the brake pads which it does have would squeal only when washer stops spinning if they were bad just like squalling brakes on or vehicle the are quite till applied if bad,what the most likely cause of the noise is going to be the tub bearing,it is on the bottom of the outer tub. The inner and outer tub must be removed,it is advisable if replacing the tub bearing that you also replace the tub seal since it may not seal correctly once taken apart and leak badly.The hub taht connect inner tub to transmission must be removed so ya can remove the outer tub it requires a special wrench which is not to expensive but nothing else will work. IF ya want to go ahead and repair this the part numbers are;
TUB BEARING 40004201P
TUB SEAL 35-5655-1
SPANNER WRENCH 306P4
PROCESS TO REPLACE BEARING;
unplug power
remove front panels
remove screws holding top to cabinet
remove plastic tub cover by down slightly and lift tabs
remove agitator
remove bolts from hub under agitator and remove inner tub
use that spanner wrench and a hammer on nut on hub and remove nut in counterclockwise direction by hitting wrench w/hammer
lift off hub
remove rubber tub seal
remove all springs from outer tub by locking on vise grips and pull springs off
remove bolts holding outer tub to the to tub support
pull off outer tub and set down so bottom is facing up
remove old bearing and install new old
reassamble in reverse order
this is a link for parts breakdown http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Washer-Parts/Model-NAV2330AWW/1268/0153200?pathTaken=&prst=0&shdMod=NAV2330AWW
to order parts order from sears or for a cheaper price by a little rearsch from
apdepot.com
assuredparts.com
appliancepartspros.com
repairclinic.com
Good luck, if you have any question reply and ask away.
Gene
Aug 07, 2011 | Amana NAV2330AW Top Load Washer
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Can bearings be removed without removing the drum itself on a wma54
sorry no its a big job but here goes isolate from electric and power remove lid and rear bottom cover.
remove soap drawer and remove screws you can see behind it then remove fascia, then undo the door seal and plinth cover ,then remove front panel.
then remove dispensor hose from tub, go to the back remove sump hose and motor and wiring to element then remove top front sub frame and undo the top and bottom weights then remove the pins that hold the suspension legs to the tub lift off the springs and the tub is free.
Then split the tub knock out the old replace with new that is assuming you dont damage the shaft of the drum support whilst removing il then do it all in reverse this normally takes me 2 hours it might take you 2 days but hey lifes full of challenges good luck
Sep 28, 2009 | Hotpoint WMA54 Front Load Washer
I need to remove the aggitator to remove the inner basket? maybe?
YOU SHOULD HAVE A SPANNER WRENCH TO REMOVE IT BUT IF YOU HAVE A SMALL MONKEY WRENCH AND ENOUGH MUSCLE YOU CAN REMOVE IT
Aug 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Outer tub seal
you must first remove the agitater,then remove the inner tube,you'll need a spaner wrench,you now can see the tub seal,how you need to remove the 3 bolts around the bottom of the outer tub,now you can remove the outer tub and replace the tub seal,or use some 3m gasket seal,up to you,you can get a new tub seal on line for $10,let me know how you do-mike
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Sep 05, 2007 | Washing Machines
Washing Machines Logo
649 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
