F21 door locked won't work help!!!!!!!!!!!!!
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washer, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
SOURCE: hi, i have a kenmore
Drop front panel
open pump sump
clear objects.
Retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: What is the cu ft capacity of a Kenmore Series 80
The capacity of the Kenmore 80 series is 3.0 cubic foot. The 90 series washer is 3.2 cubic foot.
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
SOURCE: door is locked code F21 wont run or cycle or empty water
Try hitting the stop button twice - we are having the same problem but ours isn't draining
