A/c works fine, when we change it to heat sometimes but very rarely the compressor will come on and give us heat for a couple minutes, then the compressor shuts off. most of the time the compressor wont even turn on. no humming, clicking etc. Condenser is clean.
SOURCE: window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
SOURCE: my outside condenser fan motor hums and slowly
hi there,
check the capacitor of your condenser fan,if busted replace,although thats the common causes of hummimg motor,it can't start,consider also after replacing capacitor still hum,check the motor start winding,and the supply from the source of relay in control panel.have a nice day
SOURCE: Condenser fan turns slowly and then compressor shuts down
clean bushing and allign them very well.
SOURCE: My compressor shuts off after a few minutes
Hello
One possibilty is the out side coils or condenser is dirty.And the unit is shutting down on high heat.
Try cleaning the outside coils with some simple green cleaner or even comet spray, then rinse with a hose.
