Water fils to about half way up on rense cycle and water keeps runing down the drain. I replaced the timer which did't help
Your drain hose is too far down the drain standpipe, or the standpipe is too short. Either one will cause the water to siphon out of the machine. Pull the drain hose all the way out of the drain and insert no more than 6" of hose into the drain. Secure the drain hose to the fill hoses using a plastic tie wrap or similar item to prevent drain water pressure from knocking the hose out of the drain.
