Might need the body control reset.
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
SOURCE: rear driver side window won't roll down on 2003 lexus es300
I had the same issue with the passenger side rear window. I took the panel off (one screw under the window switch and one screw located behind the door handle. There is a small black cover over the screw.) I then took the motor off of the door and track system. After the track was off, I plugged the motor back into the wiring harness and tried the switch. Mine actually worked and the gear spun, if not, it will be a pricey window motor about $150-$250 depending on where you get it. Good luck! Sean
SOURCE: Power door locks and driver side power window not
You can do it yourself.
Couple of times when you replace the remote battery, you might have them not working/ responding but just follow the procedure below.
Stand close to the car, hold down the open and close knobs for about 10 seconds. Press them at the same time for 3 seconds; then press the open button as the car opens.
The above procedure is applicable to a lot of car brands. It does not matter how many knobs you might have on the remote fob.
I have carried this procedure out on a lot of brands ranging from Honda, Toyota, Rover, Ford, etc. and it works perfectly well.
Good luck and Rate this.
Cheers
SOURCE: BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
SOURCE: Power door locks and driver side power window not working
The solution to this issue was recently discovered during our most recent trip to the shop. We told them not to leave the window down when they changed the battery... BUT DID THEY LISTEN...NOOOO.
So quite by accident I was finally able to correct and then test fail the system and test and fix again...
Here you go.;
1. disconnect the battery and connect both the positive and negative cables together(after disconnected))
2. disconnect the window and lock controller in the driver's side door.
3. Leave cables connected for at least 5 minutes
4. Re-connect door window controller and locks wiring harness
5. Place the key in the ignition and turn to the run position
6. Connect Battery starting with the negative cable(ensuring not to connect then disconnect, (one swift motion)
7. open drivers side door and turn key to the off position(do not remove)
8. You should hear a series of dings
9 Once dings are heard remove the key from the ignition and you should hear the door lock solenoids activate..
10. Congrats.. Your done and the windows and locks work.
