Motorola Mobility H700 Wireless Headset Logo
c
chris harrelson Posted on Nov 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I plug it in its green when I unplug it the thing will not do anything
I have left it plugged in for hrs I have even left it charged for days and still cant get it to do anything can you please help
  • Official Brand Answer 1,623 Answers
  • Posted on Mar 05, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350232
Points
5677
Chris
Charge with boom closed. If previously paired with your phone and bluetooth is enabled. It should auto connect when boom is opened. Pairing on this model is tricky for some.
Mark
Motorola Support
The lights are flashing and it will not do anything. I plugged it in and it shows 2 red lights, 2 yellow , and 4 green . It is moving from left to right since I plugged it in an hour ago.
Make sure that you are charging the chair 12-14 hrs before driving. charge with the joystick on, make sure both freewheel levers are in locked position.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Bon-Ton Greene Gray Portable Battery Backup for I Phone 4S Won't take a full Charge? Or Charge Phone
I can't see that anyone has commented so far :-(
Sounds like a dud battery, and if new should be returned. It would help if you can borrow a voltmeter and test that both the charger and the battery show a voltage. [a local electrics shop may help there]
2helpful
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
2helpful
I just got my bt15 headset and I have had it plugged in for 3 hrs.It works while being plugged in but it doesn't even turn on while unplugged.
Let it charge for an entire day (24 hours)
that'll do the trick. If not, then you have a battery issue . . .which is not uncommon.
The poodle guy
1helpful
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
I just got my S3000 and plugged it in for charging. It says that it takes 2 hrs and 10 minutes to charge but the light still keeps flashing green (way past it's 2 hour mark). Is my camera broken or does it...
that's happening to me right now also. i plugged the charger in around 5pm and the green light is still blinking til now and the times 11.24pm. i dont know if somethings wrong with it?!
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
1helpful
605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Laptop won't power up
when u get power on of your laptop .u seen Red/orange light blink 4 times on front panel.it means your laptop battery is not getting charge.please get charge for minimum 6to 8 hrs & then try to on .if y u laptop battery is get charge u r laptop will started on (also confirm your A/c adapter is working .green light is display on front panel it indicates charging on )
Battery charge
Put 2 batteries in flashlight and ran completely dead. Charged them in 1hr. 50min. Pulled plug per directions for first time charge and plugged back in. Light went out in about 10 - 15 min. Plugged in third time with same results. Is this normal. Haven't tried them in camera yet.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
