I have a canon 5180 with the message "tx image set not to display" and its preventing us from scanning to email. it happened once before & i didnt personally resolve it, but its happened again & i can figure it out. any help?
September 11, 2008
Product : imagePRESS C1, All Fax Capable imageRUNNER Models
Title : Setting the TX Terminal ID print options
Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division
1-800-528-2830
Same problem, but on a Canon iR4080. Machine gets hung up on E-mail/Scan, and never finishes sending the job. Eventually the error message is "TX IMAGE SET NOT TO DISPLAY"
