Samsung SMH9187 Microwave Oven Logo
S
SKMan Posted on Nov 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intermittent Power Loss
I have a Samsung SMH9187 microwave, that is just over 2 years old. The unit went dead couple of days back, no power at all, no clock, no keyboard power, no light. Checked the fuses - they are good. Two days back, I was frustrated and slapped the microwave on the side by the keyboard, and voila, it came to life. Worked perfectly fine, until I happened to close the door a but quickly today morning when the power went off again. I suspect a loose connection somewhere in the board under the keypad or somewhere there. How do I go about figuring out the loose connection?
Dave Glabb
Level 3:
Master:
  • Master 257 Answers
  • Posted on Nov 19, 2013
Dave Glabb
Master
Level 3:
Master:
Answers
257
Questions
Helped
169456
Points
1085
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 05, 2007
SOURCE: Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 28, 2007
SOURCE: intermittent keypad operation
A new keypad is not difficult to install, and can be worthwhile.
It's part # DE34-10139B and you can get one for $18.71 plus shipping from http://www.samsungparts.com
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We're able to install them for folks who don't want to do it themselves.
Anonymous
  • Posted on Jan 13, 2008
SOURCE: Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Anonymous
  • Posted on Apr 17, 2009
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Anonymous
  • 6771 Answers
  • Posted on May 06, 2012
SOURCE: display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Unit is completely dead
please check the fuse - you will be able to locate it on panel. - replace it and the pcs is ok --
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
1helpful
The oven has no power. The outlet is hot. The unit will power up intermittently, but as soon as you try to turn it on it loses all power.
This is a safety feature of the microwave. Unplug it and leave the door open for about 10 minutes and it should work again with no problems.
P.S. My kids overheat mine all the time making pop corn.
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Whirlpool MH3184XP - No Power
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
5helpful
2answers
Sharp Microwave Model R-1471A
You can find a wiring diagram for model R1471 at our site:
http://207.234.249.73/mwd/r1470_wiring.jpg
Samsung microwave
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
